Hey i have a couple of questions, my knowledge is very limited when it comes to DVD burners.
How do they exactly work, can you actually go to the store buy a DVD and then burn another copy just like the original one? Also what is the best DVD writer in your opinion thats avaliable, oh and how long does it take to burn a dvd with current dvd writers since they are not nearly as fast and CD writers.
Thank you, and if i asked any of the wrong questions, im sorry.
Also how difficult is it to burn, you have to first insert a dvd in dvd rw and then rip it to your hard drive right? After that you burn it on a DVDR disc?
What kind of computer do you have to have for that?
I have P4 1.4ghz 512rd ram and GF 4 ti 4600, if that enough or CPU is too slow?
I read about HP DVD200i burner, does anybody have it, did you have any problems with it? How fast does it take to burn a DVD on this burner.
Thanks again.
I tried reading n00bie guides but i don't understand a lot of terms that being used. -
Ok I will try and explain a few things
DVDs come in single layer (DVD-5 about 4.7GB) and dual layer (DVD-9 about 7.95GB), All current dvd writers can only write single layer so if the DVD-Video that you buy is single layer you can just rip it to your hard disk and then copy it to DVD but if it's dual layer you will have to rip it to your hard disk and then either, strip some stuff out of it like extra audio track OR Re-Encode it in a lower bitrate.can you actually go to the store buy a DVD and then burn another copy just like the original one?
DVDs come in two main standards DVD-R(W) and DVD+R(W), we're not here to discuss what's the best and nobody knows who will eventually become triumphant so it's better to choose a writer that can do -R and +R. My recommendation is the Sony DRU-500a it's a 4x DVD-+R writer and a 2x Re-Writer.what is the best DVD writer in your opinion thats avaliable
To burn a full DVD it takes about:how long does it take to burn a dvd with current dvd writers
60min at 1x
30min at 2x
15min at 4x
And yeah your computer is fine for burning DVDs but I suggest you get a seperate DVD reader as these are faster at ripping.
Hope some of this helps
Thanks a lot for typing all that and taking time to explain, ill look into that sony burner, also is there any way to find out is a DVD movie comes on dual layer or single layer, do most movies on dual or single layers?
Thanks again. -
Most of the last year or so are dual layer. It will say on the back of the dvd case if it is a dual layer DVD.
May the force be with you.
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
N00bie question about MP3 players and docking stations
By Eat Right in forum ComputerReplies: 4Last Post: 9th Jun 2009, 11:42 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
New to DV, I have several questions.....
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 4th Dec 2007, 00:10 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 15:00
