Hey guys, ran into a very good divx copy of Resident Evil, but the default audio stream is in french, duh..., how can I extract the second stream which is in english? I usually use virtualdub to extract the AC3 audio and then headache to convert to mp2, but I dunno how to get the second audiostream. I would like to convert it to (S)VCD to be able to watch it on my stand-alone DVD player.
Thanx in advance
/ Tompa
I suggest a method which uses Graphedit. Try it, and if you get bogged down, report back.
He he, I kinda found a solution myself, checked the www.doom9.net page and got some hints in the AVI/AC3 guide and how to use the "aviMUX GUI" with filters, there You can import the divx directly and load it, and the audiostreams will show up automatically, then just rightclick on desired stream and "save as".....
it was just as easy as that....
// Tompa
How do you extract ac3 from m2ts when tsmuxer doesn't read the audio?
By yoda313 in forum AudioReplies: 6Last Post: 1st Jan 2011, 08:28 -
HELP for extract DTS or AC3 audio from MKV
By Riversound in forum AudioReplies: 5Last Post: 29th Jan 2010, 10:56 -
extract entire ac3/dts audio track from a DVD
By shiet in forum AudioReplies: 1Last Post: 24th Feb 2008, 02:26 -
Any 1Click Blu-ray / HD-DVD method to extract selected Video/Audio streams?
By jmone in forum DVD RippingReplies: 3Last Post: 2nd Jan 2008, 10:12 -
How can I extract AC3 audio from VOB files?
By Sean_ve99 in forum EditingReplies: 6Last Post: 1st Oct 2007, 04:56
