I am going to build own DVR out of old computer parts. I was going to do this before and had a great piece of software. It had only 3 bottons:
record
stop
set timer.
It was very simple to use and only used a mouse. ONly using a mouse is important to me as then I can get a wireless one and have myself a nifty remote!!!!
So even if you dont know the software I am talking about I am open to reccomendations.
baker
Results 1 to 9 of 9
Depends on your cap card - does virtualdub sound too complicated? The manufacturer's software?
Panasonic DMR-ES45VS, keep those discs a burnin' -
Afradi it does.
That program I was talking about was making great strides when I had a big time computer crash and lost all my hd info. Its actually a front end for Vdub. You can set up vdub using whatever settings you want, resouloution, codec etc...
Then this easy to use front end would start it for you at the touch of a button. And it was very easy to set the timer.
It saved the programs as dates so I didn't have to type names. This was very usefull for my wireless mouse idea.
baker -
Try http://www.geocities.com/GeoFileSer0002/eigene/VDstartProCur/vdstartpro.html maybe? Seems russian homepage was down
Virtualdubvcr rocks
It's modified version of virtualdub with a GREAT timer feature and a few more niceties
I know exactly which one you are talking about. I have it loaded at home. If it is the correct one, you can set it to use bios alarms, or resume from suspend, and all that. There is a handy little record dialog where you can instantly start recording by setting a duration.
It used to be called VirtualVCR, then his website said he was renaming it to VirtualDVR.
Try here! http://www.virtualdvr.org/index_en.htm
Let me know!
Which is better - usb stick vhs cap or hd-pvr cap + convert for vhs to dvd?
By yoda313 in forum Capturing and VCRReplies: 22Last Post: 22nd Dec 2011, 20:13 -
U lead movie wizard with easy cap
By arthurtwosheds in forum Newbie / General discussionsReplies: 1Last Post: 26th Jun 2011, 16:41 -
By arthurtwosheds in forum Newbie / General discussionsReplies: 1Last Post: 26th Jun 2011, 12:48 -
Errors burning movie to BD-R using HP bd340i burner & PowerProducer softwar
By BDNov in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Feb 2011, 08:34 -
Easy Cap USB 2.0 Video Adapter
By Joy123 in forum Newbie / General discussionsReplies: 3Last Post: 25th Jan 2011, 07:53
