When making an image in Video PAck 4.00.079 I get this error pop up box while building disk at 70%.
|-----CeQuadrat Video Pack--------|
| C:\windows\temp\vv.scr Line 219: |
| Illegal MPEG Packet~~~~~~~~~|
Cound this be cause by my TMPG encoded eVCD stream ? I set the audio at 64k to concerve space to fit on 1 CDR. The result mpg plays fine and was burnt with NERO 5.5 ,plays fine in standalone DVD Apex600a. I have all done in VP 4.0 my title menu to go to movie or chapter menu , then I have the mpg in 10 min chapters. I set the menu page with 10 stills and a return to title choice. I rechecked all the nodes for entries and they are the corect tiem for each one @10:00 min apart. I used MPEGSequenceMaker to add seqences to video then remuxed. I don't know what that error is. Is it because my mpg is not true VCD compliant?
<font size=-1>[ This Message was edited by: DaeDreamah on 2001-08-29 03:49:32 ]</font>
The short answer is "yes."
The slightly deeper answer is your video may be fine and VP4 may accept it, but VP4 is a stickler for audio being to spec.
You are having a different experience in Nero because Nero is designed to be very forgiving for off-spec everything. You could encode a video at one bit per second and Nero will let you burn it as a non-compliant VCD!
If you want to make this sort of non-standard VCD, your only hassle-free option is Nero. If you want to use entrypoints on your non-standard VCD, VP4 is not the way to go. You'll have to explore the VCDImager (+GUI) options.
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 10:50 -
Creating Youtube (mp4) from mp3 and image
By robertpnl in forum Newbie / General discussionsReplies: 5Last Post: 6th Aug 2010, 09:11 -
LCD displays weird pop-up box
By smile_03 in forum DVB / IPTVReplies: 1Last Post: 8th Jan 2009, 22:57 -
Creating cartoon video from JPG image
By richnz in forum Newbie / General discussionsReplies: 2Last Post: 5th Jan 2009, 15:18 -
Attempting to demux VOB gives pop-up "file error" window eight ti
By taa in forum ffmpegX general discussionReplies: 6Last Post: 31st Aug 2008, 02:02
