  1. is it possible to merge 2 svcd BIN files? if yes, how?
  2. Guest
    You cant merge the bin files. You can merge the svcd mpgs if you extract them with for example isobuster,cdmage,virtualdaemon
    www.vcdhelp.com/tools#other
    www.vcdhelp.com/edit#svcd
