Hi,
I have taken some footage and captured it @ 384x288x25fps using virtualdub encoded using Divx5 6mbps. Replying this on the PC is 100% as good as the feed from the camera!
I have then edited the footage using MovieXone using the same 384x288x25fps settings.
However when I render the edit the final .avi is pants!! poor image!
I have tryed playing with the Divx setting (2Pass etc) but no good.
I did used to use a MPEG4 Avi codec which was much better till my last PC died and now I don't know what it was or were to get it (3rd Party jobby)
Can anyone help either with the Divx settings? is this a MovieXone problem or can someone recommend a better codec to use.
