Can any1 tell me what Linear quantizer in DVD2DVD-R does? Iaccidently let it unchecked eventhough when I checked with biterate viewer it said it WAS linear. Will I end up with garbage? tell me I don't have to reencode it.
[-Neoh*-]|[-Cheers-]
@ Neoh, I have not had to use the Quantizer Linear function as of yet, and I have never used bitrateviewer. I use DVD2AVI and/or Vobrator, but I can tell you that if you are using movies which are "interlaced" then you need to have that Linear Quantizer scale box checked. Hopefully the film you were reencoding wasn't interlaced. If you hit the "help" tab in DVD2DVDR and scroll down to the very bottom, Chat Walker lists what options are best suited for both Progressive and Interlaced films. Use that info and you should be fine.
thx for the tip, i didn't check the bottom of the help file in dvd2dvd-r
For the movie it came out perfect, so I still have no clue on what it does[-Neoh*-]|[-Cheers-]
AVStoDVD - Quantizer..?
By VenusAndMars in forum Authoring (DVD)Replies: 16Last Post: 15th Jun 2012, 08:59 -
Is DivX Quantizer 1 Loseless?
By Anakin in forum Video ConversionReplies: 6Last Post: 15th May 2009, 23:01 -
Is There Much Difference Between Quantizer 1 And 2 In Divx?
By Anakin in forum Video ConversionReplies: 8Last Post: 17th Apr 2009, 16:12 -
Xvid Quantizer Codecs
By theninger in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 11:54 -
Quantizer in Alltoavi
By drstew in forum Portable VideoReplies: 1Last Post: 30th Mar 2008, 15:34
