  1. I have a file in the Xvid format with ac3 ...
    It does not play well in most players I have (i think the ac3 screws things up). The video looks kinda broken up and slurs around (almost like ya on drugs - what ever that may be like !!!) ...
    However, the video will play OK in vertualDUB - although the audio is not supported .... So I have done the following ...
    I Streamed in audio in V.Dub to a ac3 format (actually was a .wav but ready for renaming). I then used AZID and Besweet to change the ac3 into a full .wav file. This has worked fine and I now have a 700Meg file of the wav of the film ..
    Now I then have tried to use the following guide :
    XviD AVI -> Mpeg1/2 (VCD/SVCD) with TMPGEnc - easy way
    Now by changing the settings in the environment section of TMPGEnc (as described in the above document) it achieved the follwoing :
    1) It DID allow me to load the avi (XVID), which before it did not ...
    So far so good !!
    Si I then selected the audio and then tried to start the process of producing the VCD (MPEG) I wanted ...
    Hmmmm the problem is as follows :
    TMPGEnc combines the audio and video OK. BUT, the resulting image (that sluring effect) was present . I thought that it might be something to do with my media player -
    So ...
    I opened the partly created MPEG (from TMPGEnc) in VirtualDub to see what happend. Thjis is the effect :
    1) Unlike when I tried to open the avi (XVID) before and the sound was not there - but the video was perfect, NOW .. both the audio and video are present but EVEN in Virtual Dub that video has the same sluring effect ...
    So where am I - Hell knows !!
    It seems that :
    a) The avi (XVID) will not play well in my media players
    b) The avi (XVID WILL play the video very well in virtual DUB
    c) A combination of Virtual DUB and AZID (etc) will sucessfully remove the ac3 audio and create a wav file ...
    d) TMPGEnc WILL recombine the video and audio (after changing the settings in - XviD AVI -> Mpeg1/2 (VCD/SVCD) with TMPGEnc - easy way - )
    e) The resulting output of TMPGEnc has this crazing sluring effect so I'm not better off than when I started ....
    There seems to be to competing problems that make this particular movie difficult :
    a) its Xvid
    b) it has ac3
    I think I have solved b) by creating the WAV ..
    But how do I solve this video issue. I might have thought the video was simply naff had it not been for the fact that Virtual DUB will play it no problem (except for the audio which i understand) ...
    I'm trying to understand this .... advice and thoughts would be very helpful !!
    thanks
    Mark
  2. hmm trying to think for myself here ...
    if VirtualDUB plays the vid fine - should I be streaming from this into TMGEnc (how eber that might be done) ...
    Mark
  3. YES YES YES YES !!!..
    For once I help myself (and perhaps someone on here) ...
    All solved with Frame serving from Virtual DUB into what ever encoder you feel like using ....
    YES YES YES !
  4. Banned
    Dec 2002
    Somewhere I belong
    NOW I know the solution to this shit.
    I uninstalled all DivX codecs and xvid codecs.Then I Installed only xvid to test if it worked and it did but with no sound cause it had ac3 sound.
    You can install xvid codecs from here:
    http://www.divx-digest.com/software/xvid.html
    Then I installed all DivX codecs separat (Not from Nimo).
    http://www.divx-digest.com/software/divxcodec.html
    After that I installed Nimo Pack but unchecked all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow 2002-04-19. Install Nimo from here:
    http://www.btinternet.com/~nimosiro/
    Now all should work fine!
    By the way,AC3 comes with Nimo Pack!
    Dec 2002
    devon UK
    cheers for that crack_man, I was having exactly the same prob, now sorted
  6. Banned
    Dec 2002
    Somewhere I belong
    Yeah,I have read all over the forum about the xvid but I got no answer so I experimented with the codecs and finally after 2 weeks I managed to solve out the problem.
    Itīs great that I can help other.
