    Nov 2002
    Holland
    Hi
    I have a problem with the film Swordfish.
    I've ripped and muxed it with dvd2dvd-r and with authoring mode on IfoEdit....(english audio and dutch subtitles)
    Everything is going alright no errors or what so ever.....
    But when i wanna play the movie in PowerDVD i have no subtitles even after selecting it (i have all the needed files)...
    CellTimes.txt
    Checked_Audio_0x80_English.AC3
    Info.txt
    ORIGINAL.IFO
    Subtitle_0x23_Dutch.SUP
    Video_0xE0.AVS
    Video_0xE0.d2v
    Video_0xE0_NEW.M2V
    Someone ????
    Crawl
  2. i had the exact same problem.
    so i decided to use maestro to author and subrip for the subs.
    everything turned out great.
    thingimijig.
    Nov 2002
    Holland
    I've done it all with IfoEdit......film doens't need to be reencoded...
    but thanks......anyway
  4. either i am reading your post wrong or you didnt get my point.
    i used dvd2dvdr to get the m2v, ac3 and the .sup files like you did.
    then like you i used ifoedit to author them back together but when i played them back in powerdvd i had no subtitles.
    so i put the m2v and ac3 files into maestro to author and reripped the film in dvddecrypter so i could use subrip to get the subs in a .son file which maestro accepts.
    compiled it and the subtitles worked.
    tried a few films with ifoedit but never had a subtitle work yet so i think i will stick to maestro.
    thingimijig.
  5. i suggest you should use vobedit for your subtitles if you are going to author with ifoedit. just follow this guide form step 3 and on and your subtitles will play just fine.http://www.doom9.org/index.html?/mpg/ifoedit-dvdauthor.htm
    Nov 2002
    Holland
    @thingimijig
    I think you don't readed my post wrong and i know what you meaned by your first post but there are more ways of making backups..
    When a film doens't need to be reencoded (which i, with this film, found out after using dvd2dv-r...... ) i decrypt in file mode and use ifoedit to make a direct backup.
    But your way is a good one but i hate meastro (don't ask me why) i rater use scenarist which i think works much easier...but again with this film you don't need to author..
    @ghoster
    I will give it a try.....thanks....
