Alright, well I think I have sort of a weird problem, and it might be my wiring setup that is to blame:
I burned a Data CD with a 500mb MPEG-1 on it, and my DVD player recognized it as an mp3, brought up my mp3 screen, and refused to play anything...I then went into Nero and burned it as a VCD, and went back to my DVD player, and it started playing (it recognized the length). Now on the S-Video input I had a picture that was basically garbled to hell, but with sound. And on my Y-CBR input I had a perfect picture with 0 sound. What the hell just happened? Then I burned a different movie using .bin and .cue and also using Nero, and I popped that into my DVD player and it played perfectly with sound and everything on both the S-Video and the Y-CBR. So I do not think it is my DVD player that is to blame, it is either the wiring, the way I put the data onto the CD, or the actual file itself...
Does anyone have a recommended solution for this or else something that I can try? And why is that .bin/.cue method working and making a VCD through Nero not working?
dont burn as data cd use vcdgear to extract mpeg hit vcd icon on nero drop and drag newly extracted mpeg in it and and hit burn with nero...good luck..segboy :P
If you read what I posted...thats exactly what I did the second time, make a VCD through Nero. It still didn't work.
I just tried converting it to a .bin/.cue and then burning it through Nero to see if that would help any, but it didn't.
I'm thinking it could be a frame rate problem....? The frame rate is 25 fps on my mpeg, is that compatible with many DVD players? -
Well if you're just going to spam the boards with stuff that doesn't make sense, why are you calling me a noob?
Anyway, it was a frame rate problem...I guess my DVD player doesn't like 25fps; 29.97 works perfectly. Wahoo. -
Sometimes it is that simple...
PAL / NTSC compatibility problems are difficult to identify when they rear themselves in less than common testing situations... I'm glad you've worked out your problem.
Regards.Michael Tam
w: Morsels of Evidence
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Question : Why i can't copy from Protect VCD
By indianguy077 in forum Authoring (VCD/SVCD)Replies: 23Last Post: 24th Mar 2009, 07:42 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 20:14 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 18:37
