I have a problem with the second disk skipping. What it does is it play the beginning of each chapter for a 1/2 second then skips to the next chapter.
Here is what I do to make my back-ups:
I use smart ripper 2.41 to split the DVD that are over 4.5 gb. I split the chapters in half (if possible) and put the first half in 1 folder and the second half in another folder.
I look at folder 1 and I delete everything except the VOB files. I then open IfoEdit v0.932 and run "Create IFO's". These work fine as I've never had a problem with disk one.
With folder 2, I do a little more. I start by deleting everything but the VOB files. Now because the second disk starts the VOB files later (like #3 or #4) I create blank text files and change their names to the missing VOB file names to fill in the gap. I then change the VOB number to add "00" in front of them. A sample might be:
VTS_01_001.VOB 0 KB
VTS_01_002.VOB 0 KB
VTS_01_003.VOB 0 KB
VTS_01_004.VOB 536,174 KB
VTS_01_005.VOB 1,048,574 KB
VTS_01_006.VOB 1,048,574 KB
VTS_01_007.VOB 25,498 KB
And then run VOBEdit and convert them to:
VTS_01_1.VOB 1,048,424 KB
VTS_01_2.VOB 1,048,096 KB
VTS_01_3.VOB 562,300 KB
I then run IfoEdit the same as above.
I then finish it off by burning the DVD with Nero 5.5.10
Any suggestions or Ideas about the Chapter jumping would be helpful and much appreciated.
Results 1 to 1 of 1
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 09:53 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
"data disk" rather than as an "audio disk"?
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 20th Jan 2009, 09:10 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27
