    Australia
    Over the last week I've been having major problems loading the site. 9/10 times it won't load. Occasionally I manage to get on though.
    Whats the problem? Site been having downtime or what?
    Apr 2002
    The State of Frustration
    I do not think it is the site. I have been logging on for weeks now with no problems.
    Hello.
    Australia
    Disconnecting and reconnecting usually fixes the problem.
    Anyone know how to permently fix it?
    We have no problem with the server.
    Could you try
    http://checkdns.net/checkdns.asp?domain=vcdhelp.com&submit=%A0Check%21%A0&detailed=1
    when it does not work and check under
    Checking www. records
    and tell me what it says?
    and where are you located? and what is your internet connection?
    Australia
    I'm located in Australia. And up until last Sunday I never had problems with the site.
    Also, when the site isn't working, I can ping it and recieve a response fine.
    Next time it isn't working I'll check out the page you sent, and when I'm next able to get on, I'll post what it said.
    Australia
    Ok, under www. records, it says this:
    Checking http server www.vcdhelp.com [66.28.31.2]
    HTTP server www.vcdhelp.com [66.28.31.2] answers on port 80
    Received: HTTP/1.1 200 OK (Server: Apache/1.3.26 (Win32) PHP/4.2.4-dev) e8e . .. .VCDHelp.com. . . . . . . . . . . . . . . . . .. . . . ...... . . . ...WHAT IS.... . . . ...VCD.. .. Video CD, XVCD... . . . ...SVCD.. .. Super VCD, CVD... . .
    Both when the site is working AND when it isn't.
  7. Guest
    hit start->run and type cmd
    type tracert www.vcdhelp.com
    and check where it times out when it doesnt work
    it should look something like this
    D:\Documents and Settings\Bladet>tracert www.vcdhelp.com
    Tracing route to www.vcdhelp.com [66.28.31.2]
    over a maximum of 30 hops:
      1    <1 ms    <1 ms    <1 ms  212.xxx.xxx.xxx
      2     2 ms     2 ms     3 ms  ar1-vlan708.mit.um.bostream.net [212.217.211.1]
      3     2 ms     2 ms     3 ms  betala-gw.norrnod.se [194.165.224.129]
      4     7 ms     6 ms     7 ms  telia-gw.norrnod.se [194.165.224.18]
      5     7 ms     7 ms     8 ms  217.209.242.17
      6    14 ms    14 ms    13 ms  oes-b-c1-pos0-2.se.telia.net [217.209.240.33]
      7    28 ms    18 ms    18 ms  oes-b-c1-pos2-0.se.telia.net [217.209.240.13]
      8    25 ms    27 ms    19 ms  s-b4-pos10-0.telia.net [213.248.67.65]
      9    27 ms    28 ms    24 ms  s-bb2-pos0-3-0.telia.net [213.248.66.13]
     10    29 ms    34 ms    32 ms  kbn-bb2-pos0-0-0.telia.net [213.248.65.29]
     11   124 ms   120 ms   122 ms  nyk-bb2-pos2-0-0.telia.net [213.248.64.126]
     12   128 ms   126 ms   124 ms  nyk-i2-pos1-0.telia.net [213.248.82.18]
     13   119 ms   116 ms   116 ms  pos10-0.ar.ticnycny.aleron.net [205.198.19.113]
     14   131 ms   125 ms   125 ms  ge6-2.ar.eqxashva.aleron.net [205.198.0.74]
     15   129 ms   124 ms   124 ms  204.157.5.50
     16   124 ms   128 ms   122 ms  p1-2.core01.dca01.atlas.cogentco.com [154.54.2.2
    49]
