Can somebody please explain to me what interlace options do in TMpgenc?
I noticed that when i convert a huffy avi to vcd, the image gets little blocky in fullscreen. would the interlace options do anything about that? Actually what i need is a goo tutorial on tmpgenc![]()
thanks,but what i was looking for was a tutorial that explains what all the deinterlace options actually do ( even filed, odd field, even-odd field etc etc etc..) hmmm
-- The Good Tutorial on TMPGEncNon-Interlace: It encodes your movie so that it does not have interlaced pictures... A interlace picture is a picture that has 2 picture per frame and if you remember back when I was talking about Frames Per Second I said it doubled itself, well frame A is half of the picture starting with the top line and the skipping the next then shows the one after that. The B half of the frame puts in what frame A missed, so when the frame rate is doubled you get the full picture and also your 60Hz of NTSC or 50Hz for PAL. Ok now this encoding method doesn't do this it puts frame A and B together to make frame A then doubles it to get a exact copy for frame B. Using this makes a source progressive.
Interlace: Ok this one does what I said above It encodes a 29.976 non interlaced movie to shows half the frame in frame A and half in frame B. This is for converting to 29.976FPS from a 23.976FPS movie with the help of 3:2 pulldown under the advanced tab.
Hmmmm.Hello. -
lol..But in the interlace settings, theres other options like odd field, and even field. What do THEY do? And also would fooling around with that get rid of the blocks in my mpeg?
Blocky MKVs
By romanticwarrior in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd Dec 2010, 15:06 -
FFMPEG too blocky
By IMC in forum Video ConversionReplies: 4Last Post: 3rd May 2009, 16:00 -
can you help ...ulead...mpeg... blocky
By newbie44 in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2008, 06:43 -
Blocky or Boxy?
By jethroangel in forum EditingReplies: 2Last Post: 10th Oct 2007, 21:18 -
QT DV blocky playback
By Fifou in forum Video ConversionReplies: 5Last Post: 7th Aug 2007, 10:56
