I rip my audio and video stream from dvd decryptor and I also have it produce a chapter text file for maestro. For some reason every time I try to load the chapter file I get a "I frame insertion error." The only time the chapter file loads is if I already encoded the video with rempeg2. So, for all movies under 2 hours I am stuck creating 30+ chapter points. Can someone help me out or have any tips.
True Story
Try This
On the Chapters right before I open the original ifo to extract my chapters using chapterxtractor i make a minor change.
I select presets for DVDmaestro then I make a change to the format.
I change the colon after %ss and before %ff to a semicolon. Then I open that original ifo and save my chapters.
%hh:%mm:%ss;%ff\n -
My chapter file does not have that (%hh:%mm:%ss;%ff\n) or anything like it in the code. Should it and where? Thanks
True Story
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
[ INFO ] Maestro SBT 2.6.0.0 *does* support Unicode
By Midzuki in forum SubtitleReplies: 2Last Post: 15th Jun 2010, 21:25 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 02:59
