Hi All
I have a G4 - 500MHZ- AGP running OS 9.2.1 and OSX 10.2 - with 384MB of RAM
I would like to exchange my DVD-RAM (still running but pretty much useless)
for a Pioneer DVR-105. After reading several posts, I have learned that the drivers for this drive are either already available or will be available in
OSX10.2.3 ( it is probable that I will also have to download the 4X fix,if it is not included in 10.2.3)
IDVD cannot be purchased from Apple any longer, and Iam currently using Imovie2 to edit my home videos.
Could you people help me select the right software to create DVD-Rs from Imovie2 and also to create my own music CDs. Reading the different postings it seems that "Toast 5 Titanium" and "Nero 5.5" are the most favored programs.
Your help and guidance will be appreciated (any dos and don't will also be appreciated)
Taronger
10.2.2 included the drivers for the A05/105 drive. iDVD is still available from Apple for $20...they say it's an upgrade, but it's in fact the full version and will work with the A05/105 in any G4 with OS X.
Nero does not work with OS X (barely works in 9) so you should be getting Toast.
iDVD from the Apple Store -
If you dont already have iDVD (i.e., you dont use a Mac with a SuperDrive), will the install go forward on this "upgrade" version available at the Apple store?
Yes, but it has to be a G4 with a DVD-RW (Pioneer) drive. It will not install unless it detects both. It does not look for a previous version of iDVD.Originally Posted by AntnyMD
Suggestions request for setting up PiP PC capture.
By Clickn in forum Capturing and VCRReplies: 0Last Post: 21st Apr 2008, 20:52 -
Request for allin one software advice please
By Ian Shaw in forum Newbie / General discussionsReplies: 2Last Post: 11th Mar 2008, 21:50 -
Advice Request regarding TMPGEnc, File encoding, and DVD creation w/ Menus
By Hal05154 in forum Newbie / General discussionsReplies: 9Last Post: 25th Sep 2007, 14:13 -
Newb h264 or codec advice request
By EAO in forum Newbie / General discussionsReplies: 14Last Post: 2nd Jul 2007, 01:18 -
request advice concerning undelete files accidentally lost.
By kasfig in forum Off topicReplies: 5Last Post: 21st May 2007, 16:19
