  1. When I open vcd easy it comes up with 'cant find cd writer/aspi problem'.
    I think this is why it wont burn in nero or vcd easy.
    Could someone tell me what to do.
    I need instructions.
    PLEASE!!
    thank-you
  2. search the forums for ASPI or ForceASPI
    Men know.
    Panasonic DMR-ES45VS, keep those discs a burnin'
    Seaside, CA
    There is a link to the ForceASPI drivers in the Tools section. Make sure after you install thenm, you reboot. Then select the generic-mmc driver and that will probably get you going.
