ive serached the fourms and i have seen this questions asked, but no effective answers given, so i gotta ask, i am joining 2 svcd mpegs and thjis is how im going about it
fist, i convert the bin/cue to mpeg using VCD gear,
next, i try adn join them, ive tried TMPGEnc and they join but the audio get out of sync as soon as disc 2 starts, ive used DVTool & EZ merge and w/ these it joins them but as soon as it gets to disc 2 it stops playin and it cant read anythign past disk 1, c'mon gusy i kno their is a way to do this somone throw me a bone
ohh yea, i tried VDub but it wont load my mpegs, dont know about that
I would be interested in any answers to this question. Im trying to join a 4 disk svcd into two parts so that i can put it onto dvd. Unfortunately the audio is always out of sync. Is there any software that is capable of this? so far ive tried MPEG2VCR, TMPGenc, M2 edit pro. All have failed miserably.
TIA -
Have you tried a good video editor? Ulead mediastudio pro or videostudio or adobe premiere? Ulead has trials at www.ulead.com to see if it works.
Panasonic DMR-ES45VS, keep those discs a burnin' -
I was just reading about placing SVCD onto a DVDr and it mention something about audio being out of sync if you use TMPGenc and its audio converter. The guide suggests that you use a external frequency converter called SSRC to fix the sync problem. I believe your method will work it just needs a little tweaking. Let me know if it works!
Guide: http://www.vcdhelp.com/svcddvdr.htm -
Join the 2 mpegs with TMPG, then extract the WAVS from each part so you have 2 individual wav files (after you demultiplex, you can convert the MP2s to WAVs in Winamp), then go into an application that'll let you edit audio. I just used Adobe Premiere. I just throw the WAV files in there back to back and saved it as one big WAV, then added it to the joined MPEG. Voila.
You can do it using Ulead Media Studio 6.5
Its a simple drag and drop then create-video
Im not sure if im doing it correctly but there is definately no audio sync problems BUT it takes ages to complete the process. Approx 3.5 hours to do 2x 45min clips into one 90min clip.
Please note: This was a really high quality SVCD and that may have something to do with it. Its a 3hour film which is currently on 4svcd's. Im hoping to get it down to 2 x DVD-r's
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
Joining of VOB as 1 with 2 Disc
By pboong in forum EditingReplies: 7Last Post: 13th Jan 2011, 03:57 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 21:06 -
Disc copy of a dual layer disc
By kingjames in forum Newbie / General discussionsReplies: 3Last Post: 1st Oct 2007, 14:52 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 13:50
