alot of the dvd's i have say its widescreen...but when i play it on my tv...the black bars dont show up and it pisses me off cause i'm missing the ends of the movies...can someone tell me why there not playing in widescreen format...thanks
check your viewing settings in your dvd player. if it is set to "full screen" or "pan & scan" disable that and set it to widescreen.
you may need to czech your owners manual to figure out how to do this.
also, you may want to see if you can control that through the movie itself, because some movies (such as "snatch"
give you the option of watching the widescreen version. that is not controlled by your dvd player, they just have the same movie on the dise. one being widescreen, the other full screen.
good luck fock a duck
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 11:59 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 13:22 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 20:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15
