My Philips DVD Player 950 can't read DVD-R Disks. But DVD Players "Comptability", I see it's possible for this media.
I have the same thing with my Philips 711. I'll bet it has more to do with the player hating Accu silver/purple discs than with all DVD-Rs.
Panasonic DMR-ES45VS, keep those discs a burnin' -
I think my DVD Player 950 can read DVD-R disks
I have bought the Philips DVD Recorder 890 and this Recorder write DVD+RW.
I would play the DVD+RW into the old Player and it was not possible to
read this disk.
Operating instructions from DVDR 890:
some DVD player cannot play back DVD+RW recordings. You can solve this problem by using a special funktion:
Open the disc tray with OPEN/CLOSE: Insert the disc but do not close the tray.
Hold down the number button 2 on the remote control until the tray closes.
The disc is modified.
If this fails to produce the desired result, repeat the procedure using the number bouton 3 on the remote control.
You can restore the disc to ists original condion by pressing 1.
What change the Player or the disc?
Now my old DVD Player can read DVD+rw.
I think because this special function my old DVD Player can't read DVD-R and the manuel from 950 wrote DVD, CD and CDRW and their web site can read DVD-R and DVD+R, DVD+RW
Camcorder doesn't read SD card!
By Dawood1987 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 14th Apr 2014, 07:25 -
DVD-ROM doesn´t read DVD
By jsilv in forum DVD RippingReplies: 11Last Post: 7th Mar 2010, 07:43 -
My computer doesn't read dvd+rw disk
By jayjayj2 in forum Newbie / General discussionsReplies: 0Last Post: 17th Sep 2008, 13:05 -
AOpen DUW1616/ARR doesn read DVD type disks
By phill in forum Authoring (DVD)Replies: 5Last Post: 9th Sep 2008, 20:46 -
DVD player doesn't read DVD
By hockey_fan_12 in forum Authoring (DVD)Replies: 1Last Post: 17th Nov 2007, 19:29
