With a lot of help from this forum I converted my first SVCD file (divX2SVCD). Problem is that DVD2AVI left just a few MB for third CD (my mistake probably, I missed something), so I would like to know if there is some easy way to "shrink" files without new converting. My PC needs 6 to 7 hours to convert 700 MB long divx file.
Yes, you can use VirtualDub as it can cut something out without re-encoding. I hope this guide can help you:
http://www.vcdhelp.com/virtualdubedit.htm
Hope That Helps!!!:P
If you are talking that the final product being 700mb files (I'm not exactly sure, as you said "convert 700 MB long divx file") then they should fit, as you can fit up to 800meg (mode-2, which is used for VCDs and SVCDs) on a standard 80min/700meg (mode-1) CD. You can fit even more if you overburn.
My apologies if you are actually talking about how long it takes to encode. Even on fast systems it still takes a while. I have a "fast" system (Pentium 4, 2.4gig, 512meg ram) and it takes me 3 to 4 hours to encode 45 minutes using TMPGenc and 2-Pass VBR to CVD format. -
Sorry, my English writting is realy poor, so I wasn't clear enough: point is that I'v got a three files - two are aprox 700 mb and the third is only 20 MB long. Is there any easy way to resort those files: (I have 1420 MB together and need to "shrink" it to 1400 then cut it to two parts with 700 MB) Shortly, I want to spare one CD and dont want to wait another 7 hours to reconverting original diviX.
Anyway, thank you both, I'm realy new here, so i feast on any information I get.
THX
Wega
How is a Smaller File a Better One?
By happydog500 in forum Capturing and VCRReplies: 4Last Post: 23rd May 2011, 20:50 -
.TS to a SMALLER file with nearly SAME QUALITY
By Benygh in forum Video ConversionReplies: 2Last Post: 12th Dec 2009, 10:23 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 20:48 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
plan for converting SageTV mpg's to smaller files.
By Verlager in forum LinuxReplies: 7Last Post: 6th Feb 2008, 22:56
