Has anyone else has a problem with Nero 5.5.10.0 and Sony DRU-500A with firmware 'f' and creating multisession DVDs? It seems to be stuck on "disk-at-once" (DAO).
I haven't tried but I can - what were your burning parameters (data/video etc etc)?
Panasonic DMR-ES45VS, keep those discs a burnin' -
From "New Compilation":
DVD-ROM (ISO)
"Multisession" Tab:
Start Multisession disc
"ISO" Tab:
Iso level 2
format (greyed out)
ISO 9660
Joliet checked
All three Relex ISO Restricts checked
"Burn" Tab:
Note that the "write method" is greyed out.
I'm not sure if the problem is that I can only write as DOA (Disk at once) and not by track. Everything else I try in Nero seems to work with this drive. I've heard some say that Nero does support this drive now, but I have the latest, and there compatiblilty list does not show the Sony DRU-500A. Just wondering if others where having this issue. It's hard to fill a DVD sometimes, and would like to add to it. -
I founnd another post with the answer. I did a quick format on my rewritable dvd+rw before I started the multisession. I should have clarified that I was using DVD+/-RW media and not just standard write once. I need to test, but it seems like I couldn't multisession a write once disk too, but I'll have to verify that.
http://www.vcdhelp.com/forum/viewtopic.php?p=250550&highlight=multisession#250550 -
Normally the burnprogram should check the media and (quick-) format it before writing onto it if thats needed.
With all my -RW & +RW discs it happens this way - using Nero 5.5.9.x.
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 14:10 -
Will Nero 7.0 do a Multisession DVD
By scustalow in forum Software PlayingReplies: 6Last Post: 1st Oct 2008, 12:16 -
NERO can not keep a Data CD Open- no multisession
By src2206 in forum ComputerReplies: 4Last Post: 19th Aug 2008, 14:23 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 11:52 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 10:21
