I have a problem putting an AVI onto a VCD. I have a bunch of 30minute AVI's. All of them convert to VCD without problems, using NERO 5.5.8.2, except one which returns the error "Error during encoding".
I tried to convert it to MPEG using TMPGEnc but the sound gets lost!
The AVI plays perfectly in Microsoft Media Player 8.
It's got me beat!
Any helpful suggestions appreciated!
Originally Posted by K7973
Use TMPGE...much better.
The message you get might indicate some bad frames.
Run it through the Virtualdub > File > Movie.avi > Video > Scan Video Stream For Errors.
You can try to resolve by
1)Running it again through Virtualdub > Video > Direct Stream > Audio > Direct Stream > Save As AVI.
2)Run it through DivFix (assuming its a DIVX)
3)Remove the bad frames (if Virtualdub detected any)
4)Extract audio using...you've guessed it..Virtualdub ,and save as a WAV and using it as Audio Source in TMPGE.
http://www.vcdhelp.com/virtualdubaudio.htm
5)Download Nimo Codec Pack
http://www.btinternet.com/~nimosiro/"Today is only yesterdays tomorrow" -
Thanks for the useful feedback!
Option 4 did the trick.
I loaded the AVI into Virtual Dub and imediately got a message about improper VBR audio encoding, which it altered automatically. The sound was then out of sync with the video. I saved the audio to a WAV and put the whole lot back together again using TMPGEnc.
Everything is now correct. I have a VCD with both video and audio, both of which are in sync.
Thanks!
BTW, what is the Nimo Codec Pack? -
The Nimo Codec Pack is a collection of mostl of the available a/v codecs used today.
If you have it downloaded 99% of the movies you download or capture will be playable and usable."Today is only yesterdays tomorrow"
Problem with creating AVCHD file for ps3 using MultiAVCHD. Please help...
By Mike789 in forum Authoring (Blu-ray)Replies: 0Last Post: 22nd Dec 2011, 15:28 -
Error creating VCD
By maruz in forum ffmpegX general discussionReplies: 4Last Post: 17th Oct 2009, 06:42 -
problem with fairuse wizard creating project
By Wizard23 in forum ComputerReplies: 0Last Post: 11th Jan 2008, 14:30 -
problem creating my own component cables.
By nick101181 in forum Newbie / General discussionsReplies: 10Last Post: 2nd Oct 2007, 13:13 -
Creating (S)VCD Stills with Audio
By Cornucopia in forum User guidesReplies: 8Last Post: 4th Aug 2007, 12:05
