Ok I have 4 episodes I want to burn off to a VCD and there a total of 81min and 18 seconds long and I only have 80min CDs so what do? Can I over burn and extra min and 18 seconds or should I use two CDs?
Assuming that your video clips are encoded using standard VCD settings, you may be able to pull it off with just overburning -- it not, you should be able to come close.
You can generally overburn safely by about a minute on most discs and drives.
Regards.Michael Tam
w: Morsels of Evidence -
Hi
Most recordables will do just fine with 1:18 of overburning. (If it really doesn't fit you can always remove the ending credits using TMPGenc.)
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
Ok thanks guys, I'm going to start ripping it now. Hopefully my CDs will beable to over burn that litte bit. I'm have Nero do I have to do anything with it to tell it that it can overburn or not?
I think that all of the CD-R media I've tested (various manufacturers and brand names) has been safe to overburn by at least 1:30.
You will have to enable overburn in Nero, off the top of my head I don't remember where the setting is. I think it's under an "advanced" or "expert" tab in the settings window.
VOB File and CD overburn Query
By scott274 in forum Newbie / General discussionsReplies: 8Last Post: 17th Nov 2009, 01:54 -
Overburn Writing
By g_pentium in forum AudioReplies: 6Last Post: 7th Aug 2007, 09:08
