heh...as the subject says, im trying to convert an ac3 audio source to wav in virtual dub and it gives me errors. is there a way to get VD to read my ac3 audio??? thanx
PX3 Convert will do what you want - no fail.Email me if you want the program
You'll find a number of proggies that can do this from doom9's site (under the software section): http://www.doom9.net
Regards.
Michael Tam
w: Morsels of Evidence -
One of the special (older?) versions of VirtualDub will let you convert AC3 to WAV, or even allow you to have AC3 audio in your MPEG-4/DivX.
I wanna make wavs into AC3 and try out an AC3 SVCD.
for the love of it
I'm pretty sure Sonic Foundry SoftEncode will do that for you. However, if your source WAV is stereo, you'll only end up with a Dolby Digital 2.0 ac3 file, which as you know, is the Dolby equivalent of .... stereo.
for the love of it
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Good luck!
FYI, AC3 isn't supported on SVCD (I'm sure you know that), but that it is also far enough out there that probably NO DVD player will be able to play it. At least, no one has ever reported getting an AC3 soundtrack on a SVCD to play on any hardware.
REgards.
Michael Tam
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 15:12 -
how can we convert ac3 to wav?
By sumeshkri in forum AudioReplies: 6Last Post: 4th Sep 2008, 03:29 -
Convert 2.05gb wav to AC3
By colt4523 in forum AudioReplies: 7Last Post: 15th Nov 2007, 07:28
