I am using Virtualdub to capture video from my camcorder.
I obtained Picvideo and used its codec to customise the format the quality etc of the capture. I burnt a 2 min section of the captured video onto a cdrw as a vcd and tried the disc in my dvd player.
Problem is that there is some kinda image break up on the edges of moving objects when playing the disc.
Is this related to the customised format I used when capturing the video. the settings etc, or is it due to the burning of the disc? I used Nero and burnt the section as vcd.
I am nearly there with this project. Just need to sort out the quality and format settings and burning.
Please help. Any advise is appreciated.
Results 1 to 1 of 1
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
