I tried looking through this forum to find a similar topic, but with no success. I need to find a GOOD program that can convert a Real Media file to an .avi format. i tried the Sonic Stream Anywhere thing. it was sayin something about the codec. too complex for me. Can anyone help?
Results 1 to 10 of 10
Follow this link
http://evc.to/tinra/
Note, I tried it, but it doesn't work on all RM files.
The only other way, is using a screen capture utility, like Hypercam or Snagit, but you will have to set your display to 256 colours. -
ummm, I don't have Realplayer G2, and can't find a copy, so I can't use the tinra program. is there a similar converter program i can use separate from any media player?
U can use hypercam to capture your video screen as you watch the RM.
Create a feedback loop through ur sound card. -
I swear, if it's not one thing, it's another. I'm sorry to keep bothering, but hypercam won't work. I can't have that "Unregistered Hypercam" floating in the top left corner of the video...are there any freeware .rm converters in existence??
If you have a version of RealPlayer that's capable of playing the clip, then Tinra will convert it. You can't capture either without this same requirement, so why not give it another shot? There's a GUI for it here.
This is the only freeware converter I know of (only converter I know of, actually). It has limitations and isn't for the faint at heart, but if you're persistent it mostly works.
_________________
Custom Windows freeware - made on request!!! http://guiguy.wminds.com
<font size=-1>[ This Message was edited by: Clint on 2001-08-30 22:27:21 ]</font>
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
I am in dire need for help *S-VHS Reporter Panasonic and Adobe Premiere Pro
By urdeluge in forum Video ConversionReplies: 2Last Post: 1st Mar 2008, 18:01 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10
