whats the difference in theses two memory sticks?
KINGSTON KVR333X64C25/512 512MB 32x64 PC2700 DDR RAM (better than 2100 2400)
6 Layers High Quality Board; CL 2.5; 184-Pin Unbuffered. Requires DDR supported Motherboard - Lifetime Warranty through Manufacturer
OCSystem 512MB PC2700 DDR SDRAM, 333MHz, PC2700, CL2.5/CAS 2.5, PC2700 333MHZ! 64x64, 2.55V, Non-Parity, Non-ECC, Unbuffered, 184pin. Heat spreader included.
32X64 and 64X64 what is the difference?
Results 1 to 1 of 1
You win some, and you lose some, and some get rained out...
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
MiniDV vs memory card camcorders - what's the difference?
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 34Last Post: 24th May 2009, 14:09 -
Memory
By ProducerHarley in forum ComputerReplies: 1Last Post: 3rd Dec 2008, 00:38 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31
