hey guys,
i've just heard of mvcd and saw some pictures and ratings 4 the conversion. sounds good, looks even better and you'll get up to 130min. of a movie on 1 cd-r (just got me a movie in mvcd quality and it looked better than a 3 svcd version).
but i just wonder if standard dvd-players support it!? my player has just wrecked up so i cannot prove it....... my dvd-rom has no problems with it.
has anybody seen a compatibility list yet?
Results 1 to 13 of 13
I have never heard of it. It sounds interesting. Can you tell me where you saw the pictures and ratings? I'd like to compare it to my EVCD template.
Here is a link. It's in Genman, the MVCD is a TEMPGE Template. I Have not tried it yet.
http://onecs.de/mvcd/ -
I looked it up, i even downloaded the TMPGEnc templates and installed them. I've finished encoding and everything, but how do I burn it? Do I go into NERO and burn it as a VCD? I'm really not sure what to do once I've finished the encoding phase for MVCD. By the way, is there an MVCD template for NTSC? Just curious.
double7007 -
Hi guys,
I just downloaded the File and checked the settings... It's just another XVCD template. Meaning it is not VCD compliant. They just lowered the audio bitrate from 224Kb to 128Kb and changed the Constant Bitrate (Which is required for full VCD Compatibility) to Constant Quality. This means that the bitrate may vary from 300Kb/s to up to 2300Kb/s. So if you encode simple frames they only take up 300Kb/s which would enable you to put 130Min of movie on 1 CDR in perfect quality. This is true. BUT.... If you have some more complex frames (fast action scenes..) the bitrate could go up to as much as 2300Kb/s thus leaving only room on 1 CDR for about 40 Minutes. (This is in very good quality though !!)
Well, i'll just stick to 4 Pass VBR SVCD's.. I don't mind swapping once.....
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
What's the big deal. Check out KVCD Templates at www.kvcd.net, and fit up to 180 Min on 1 CDR.
! Viva Mexico ! -
Here's where Mole's templates came from
http://www.kvcd.net/forum/viewtopic.php?p=23
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
i think im in love...with KVCD. hehe
its great, and im encoding a movie in it as we speak...just one question tho...how do i burn it once its done? just as a vcd?
Q-3 here: http://www.kvcd.net/forum/viewtopic.php?t=68Originally Posted by double7007
how do u create a kvcd from an avi file? where do u start on the kvcd guide? just copy and paste the first few lines of text here and ill know..
thx -
Start here: http://www.kvcd.net/guides/kguide/kvcdguide.htmOriginally Posted by koolpooldude99
It's the best KVCD related guide
well thanks.. but that starts from a dvd ripping.. i dont want to rip a dvd, i have the avi movie and wanna convert that only... where do i start?Originally Posted by kwag
Then it's simplerOriginally Posted by koolpooldude99
Just open your .avi file with TMPEG and load whatever template you want to use. I suggest you encode "video only" and encode the audio separately. You can use VirtualDub to extract the audio from your avi (DivX?) and encode your extracted WAV file with the procedures described in the guide. From there one, it's the same process, no matter if it was a DVD rip or avi encode.
http://www.kvcd.net
strange...ever heard of this?
By stompinne in forum Authoring (DVD)Replies: 8Last Post: 29th Jan 2010, 08:25 -
anyone ever heard of VOBTool?
By johnsees in forum DVD RippingReplies: 11Last Post: 25th Jun 2008, 03:46 -
ever heard of Asicer?
By mfaust1071 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Jun 2008, 11:50 -
burning mvcd with Nero 8 Essentials or ???
By Jim S. in forum Newbie / General discussionsReplies: 3Last Post: 7th Apr 2008, 06:52 -
Ever heard of sketchcast?
By yoda313 in forum Off topicReplies: 0Last Post: 24th Sep 2007, 20:37
