I tried using TMPGEnc but when I choose the avi file it says file is not valid or supported. I have the patch for TMPGEnc but still no luck. Anyone know what other prog I can use?
There's a helpful tip under the "Problems" section of the "How to encode to VCD with TMPGEnc" guide at the left. It says: "If TMPGEnc gives you an error message when opening AVI, DivX,ASF,SMR,NAV be sure that you have installed the DivX Codec and also try with the Kristal Studio Pack codecs. If that does not work try to use the old TMPGenc 12a." I had this problem also and installed the Kristal pack and it fixed it. Now I can encode away! I hope this works for you too.
How can I make alpha transparent AVI file
By MI6 in forum EditingReplies: 4Last Post: 2nd Nov 2011, 16:02 -
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
How to make AVI file to 1.4GB ?
By zovx in forum Video ConversionReplies: 2Last Post: 5th Feb 2010, 11:24 -
Can I make a AVI file smaller?
By baebbe in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2008, 16:04 -
How to make a sample of an AVI file pls?
By incrediblej in forum EditingReplies: 5Last Post: 20th Dec 2007, 08:59
