  1. Hi!
    I'm using DVD2DVDr and it works nice... but i have a litle BIG problem with the subtitles....
    In the original DVD the subtitles are white, but in the dvdr are green and i hardly can read them... the subtitles are in lighty green and in bold... the letters almost merge and dificult the reading...
    When i run the DVD2DVDr the program run for 4/5 hours and i can't do anything, because it runs ifoedit and cce automatically...
    Do you understand my problem???
    What can i do to change the color and the font (arial for example) and make my subtitles readable?????
    Miguel Neiva
    Portugal
  2. what u have to do is copy the subtitle colours to the newly created IFO's this is how.
    If you have selected Subpictures, you have to do additional steps
    - start IfoEdit
    - press 'Open' and select the path to the file 'ORIGINAL.IFO'
    - press 'Open' and select the path to new generated IFO file 'VTS_01_1.IFO'
    - mark in the upper window of IfoEdit the file 'ORIGINAL.IFO' and select under 'VTS_PGCITI' the PGC you have copied with DVD2DVD-R
    - menu 'Subtitle Color' -> 'Copy Colors from this PGC'
    - mark in the upper window of IfoEdit the new generated file 'VTS_01_0.IFO' and select under 'VTS_PGCITI' the 'PGC 1'
    - menu 'Subtitle Color' -> 'Paste Colors to this PGC'
    - press 'Save' to save the new ifo
    - close IfoEdit
    Now the files are ready to burn!
    Copied from the help file in DVD2DVDR
  3. Sorry...
    I can't do that...
    Today, i tryed to copy THE HARRY POTTER and happened me the same thing... subtitles in green and bold... i can't read the subtitles....
    The problem is that i'm new in dvd burn process, and i don't have a clear idea of what i have to do and what software i should use...
    I do a lot of reading... but i only get more loss....
    I use DVD2DVDr because it's a automatic process... the color of subtitles are predefined where? in what software? can i change the color to white and the font to arial?????
    Please, help me....
    thanks
    Miguel Neiva
    Portugal
  4. http://www.doom9.org/index.html?/mpg/ifoedit-dvdauthor.htm
    follow this guide and everything will turn out ok just don't try to add chapters because video will freeze when you try to watch it. i heard ifoedit has some kind of bug that still needs to be worked out.
