    Oct 2002
    INdiana
    I used smartripper to extract the files from the DVD using the demux option. The video_ts folder has the vob files plus the .ac3 file. How do i merge those back together so i can use ifoedit strip the subtitle and extra audio??
  2. Member wulf109's Avatar
    Jul 2002
    Smartripper has an option to re-rip from the HD. Click the folder icon in the top right corner,select the ifo file for your files and a new directory for the merged files. Do not enable strem rip.
    Oct 2002
    INdiana
    It wont let me. When i start smartripper , i click on the Movie tab then click the folder icon on the right top. I choose the VIdeo_ts folder that i previously ripped(ac3 and vob files) then comes up no DVD found.
