  1. Hallo,
    ich habe Filme mit Magix video deluxe aufgenommen. Diese will ich - wie ist mir inzwischen fast egal in DivX/Mp3 umcodieren. Bisher habe ich es nur geschaft aus obigem Programm DivX/Uncompressed PCM zu exportieren.
    Um daraus nun mein gewünschtes Format zu machen, habe ich es mit Virtualdub versucht. Bei der Umwandlung mittels
    Video->Direct stream copy, Audio->Compression (nach Lame MP3) bleibt die Umwandlung immer bei 17653230 Audio Samples stehen.
    Weiterhin habe ich andere MP3 Codecs ausprobiert. Ich habe sogar den Sound exportiert und in mp3 umgewandelt, bekomme ihn dann aber nicht mehr in Virtualdub importiert.
    Kann mir vielleicht jemand helfen ? Eventuell gibt es noch ein alternatives Programm zu Virtualdub.
    Danke schon im voraus.
  2. uuhm this is an english forum maybe its better to write it down in ENGLISH so people can read it and answer your question don't say it in german :P. we all adept so must you.
    you be dead
  3. Member vhelp's Avatar
    Mar 2001
    New York
    Hallo,
    -- -- -- -- -- translates to -- -->
    Hello,
    I took up films with Magix video deluxe. I want these - as is me in the meantime nearly all the same in DivX/Mp3 to convert. So far I have to export it only geschaft from above program DivX/Uncompressed PCM.
    In order to make from it now my desired format, I tried it with Virtualdub. During the transformation by means of stream CoPy video >Direct, audio >Compression (after Lame MP3) always stops the transformation with 17653230 audio Samples.
    Further I tried other MP3 out codec. I exported even the sound and do not get converted into mp3, him then however any longer in Virtualdub imported.
    Perhaps can someone help me? Possibly there is still another alternative program for Virtualdub.
    Thanks already in advance.
    -vhelp
    ..from a website translater, he, he...
  4. Oh, excuse me. I didn't realize that I have to write in english here.
    Besides all the smalltalk in the above statement, there is one central question:
    Does anybody know, how a avi file coded DivX/ PCM can be transformed with Virtualdub into DivX/Mp3. The special problem is, that loading the video with Virtualdub and using the settings "Video->Direct stream copy, Audio->Compression (nach Lame MP3)" doesn't work, because the transformation stops after 17653230 Audio Samples. I have tried other mp3 codecs too, but nothing changes.
    Is there perhaps another tool which could work ?
