Can anyone please help I have downloaded loads of movies some of them are dvd rips they are now avi files. and I cant, put them no my dvdr/rw it keeps saying that the file is unsupported if the movie is split in 2 it will work but the full movie will not work
Heeeelp
Thanks![]()
The full movie AVIs are probable DIVX encoded versions of the original DVD MPEG2. To be used as a DVD you would need to re-encode them back to MPEG2 DVD compatible format (see conversion guides). Otherwise you would watch them on your PC.
The ones that are split are typically VCD compatible MPEG1 files, which your burning software recognizes as a legitimate video file format. Most movies need to be split to fit on VCD. -
You can download or buy pinnacle express, it cost $25.00 at your local CompUSA, all this software does is it takes your AVI files and makes DVD from them, so it does it's own mpeg2 encoding. You can even make menus and Chapters.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
