  1. ill compile with ./configure-&& make all
    make install
    configure will give me this output:
    Summary for transcode 0.6.3 features:
    static AV-frame buffering yes
    DVD navigation support with libdvdread yes
    link against local lame library (>=3.89) | 3.92 yes | yes
    support for network (sockets) streams yes
    avifile API support yes
    libmpeg3 dependent modules yes
    quicktime dependent modules no
    libdv dependent modules yes
    liba52 audio plugin (>=0.7.3) | default decoder no | yes
    libfame video encoding plugin yes
    nasm dependent modules yes
    ImageMagick dependent modules (>=5.4.3) no
    libjpeg dependent modules | mmx accel yes | no
    libxml2 dependent modules no
    mjpegtools dependent modules no
    experimental v4l support yes
    experimental lve support no
    X11 dependent filter plugins yes
    liblzo dependent modules no
    libpostproc dependent filter plugin no
    experimental Ogg support | Vorbis support no | yes
    make all give me an eror:
    /home/buildid/temp/transcode-0.6.3.20021219/aclib'
    /usr/bin/nasm -felf -g -o memcpy.o memcpy.s
    memcpy.s:197: parser: instruction expected
    memcpy.s:198: symbol `movdqa' redefined
    memcpy.s:198: parser: instruction expected
    memcpy.s:199: symbol `movdqa' redefined
    memcpy.s:199: parser: instruction expected
    memcpy.s:200: symbol `movdqa' redefined
    memcpy.s:200: parser: instruction expected
    memcpy.s:202: parser: instruction expected
    memcpy.s:203: symbol `movntdq' redefined
    memcpy.s:203: parser: instruction expected
    memcpy.s:204: symbol `movntdq' redefined
    memcpy.s:204: parser: instruction expected
    memcpy.s:205: symbol `movntdq' redefined
    memcpy.s:205: parser: instruction expected
    make[2]: *** [memcpy.o] Fout 1
    make[2]: Weggaan uit map `/home/buildid/temp/transcode-0.6.3.20021219/aclib'
    make[1]: *** [all-recursive] Fout 1
    make[1]: Weggaan uit map `/home/buildid/temp/transcode-0.6.3.20021219'
    make: *** [all] Fout 2
    make install will give
    make[2]: Weggaan uit map `/home/buildid/temp/transcode-0.6.3.20021219/libioaux'
    make[1]: Weggaan uit map `/home/buildid/temp/transcode-0.6.3.20021219/libioaux'
    Making install in aclib
    make[1]: Binnengaan van map `/home/buildid/temp/transcode-0.6.3.20021219/aclib'
    make[1]: *** [memcpy.o] Fout 1
    make[1]: Weggaan uit map `/home/buildid/temp/transcode-0.6.3.20021219/aclib'
    make: *** [install-recursive] Fout 1
    as result avifix wont work , so anybody could help me with these errors ??
    thankss
  2. found the problem mjeg tools aint compiled well
