Hello Bilestyle,
Below is the terminal output for a session . I was getting an error with "No such file or
directory" and subsequently **ERROR: EOF in WAV header...
I noticed that a52dec-0.7.4 is looking for an audio file in the location /Users/adminst/Desktop/episode1/BringItOn/BRINGIT/audio.ac3 although I specified /Users/Administ/Desktop/Test on the "Select Input/Output" screen.
I did specify the former directory at one time but not during this session.
Have you run into this before?
Thanks!
[Administrators-Computer:~] administ% sh /Users/administ/Desktop/Test/shell
8:19AM up 1 day, 11:10, 5 users, load averages: 0.82, 0.67, 0.71
bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
Saving stream 0xBD, substream 0x80 into file audio.ac3...
File /Users/administ/Desktop/Test/VTS_04_1.VOB is an MPEG-2 Program Stream
Summary:
MPEG Packs = 6419
System headers = 36
Other stream 0x05 packets = 1, total bytes = 2888
Other stream 0x0A packets = 1, total bytes = 5008
Other stream 0x22 packets = 1, total bytes = 16885
Other stream 0xB3 packets = 1, total bytes = 11495
Private Stream 1 packets = 1066, total bytes = 2149916
AC3 Audio stream 1 packets = 215, total bytes = 433440
DTS Audio stream 0 packets = 851, total bytes = 1712212
Padding Stream packets = 29, total bytes = 31498
Private Stream 2 packets = 72, total bytes = 71928
Video stream 0 packets = 5320, total bytes = 10733515
ECM Stream packets = 2, total bytes = 32768
## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
++ WARN: [mpeg2enc] If you're not using vcdimager you may wish to turn this off using -d
a52dec-0.7.4 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
No such file or directory - could not open file /Users/administ/Desktop/episode1/BringItOn/BRINGIT/audio.ac3
**ERROR: failure reading WAV file
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
INFO: [mplex] File /Users/administ/Desktop/Test/movie looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file audio.mp2 for reading.
rm: audio.mp2: No such file or directory
rm: temp-1.mpg: No such file or directory
8:33AM up 1 day, 11:23, 5 users, load averages: 3.24, 3.00, 2.07
was the input file a vob or a normal mpeg? if its a normal mpeg with mp2 audio you need to specify the audio input type in the audio/mplex tab.
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind. -
Hello BileStyle,
I think I figured it out. I had to recopy mpeg2enc back to the user/bin directory and then chmod the permissions. Must be a common problem as I found numerous posts on that topic. I found that having a terminal window open with top running was helpful in discovering what was going on. Hey, do you notice that OSex takes up a lot of o f cpu cycles even when it isn't doing anything?
Thanks again for AfroPic! -
OSex is a very leaky shoddily written program.. but thats mostly due to the fact that it never even got passed alpha/beta stage. crlf had a great thing going and unfortunately (who knows why) he has appeared to abandon it.
im glad you figured your problem out (makes things easier for me
i have a feeling we'll be seeing some new improvements in vob ripping soon enough anyways so i'm thinking osex may not be needed anymore soon. (that is unless crlf starts workin on it again)As below, so above and beyond, I imagine
Change output directory in Projectx 0.91
By ccc in forum Video ConversionReplies: 0Last Post: 8th Apr 2012, 20:26 -
FFMPEG encode directory
By darklift in forum LinuxReplies: 6Last Post: 4th Feb 2012, 00:50 -
what is the ANY! folder/directory?
By stackner in forum Blu-ray RippingReplies: 0Last Post: 27th Feb 2010, 17:07 -
Printing Directory Content
By SCDVD in forum ComputerReplies: 3Last Post: 27th Feb 2008, 13:52 -
VIDEO TS Directory to a divx file...
By JustSomeGuy in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 15:10
