Hi guys,
need help for this. Maybe this is something I have to correct.
Playing on my Toshiba SD-220E rewritable DVD (+RW and -RW) media (didn't try DVD-R or +R) burned with Nero 5.5.9.17 and Sony DRU500A, I get the lower half of the screen filled with green. Audio plays correctly.
I authored with SpruceUP, these are NTSC VideoCD mpeg I demultiplexed with TMPGenc (audio was converted to 48Khz .mpa) and imported in SpruceUP.
I am italian and my TV is obviously PAL, but NTSC VCD on CD-R and RW always worked. I get this problem only with DVD burned as VCD.
I'd like to know if this is a problem related to the player because I can bring it back and change it. Never tried with another player, but on my PC the DVD works fine.
Anyone can help ??
ThanX.
Tatase.
Ok, tried a little.
It was the player. DVD Mpeg1@VCD resolution supported, but played with half screen in green.
Changed it to a Sony and the same disc worked fine.
Bye.
Green Band Problem
By fusion99 in forum Blu-ray RippingReplies: 4Last Post: 6th Aug 2009, 12:58 -
Playing an IMG file using VLC (or Nero) -> ONLY half screen displayed. W
By htp367 in forum Software PlayingReplies: 5Last Post: 24th Jul 2009, 15:37 -
green band after using restream
By thecrock in forum Newbie / General discussionsReplies: 0Last Post: 15th Dec 2008, 15:37 -
I get sound and green screen when playing videos..
By nddad98 in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2007, 18:25 -
Vertical band moving across screen - DVD/HDD recorder
By wizbru in forum Newbie / General discussionsReplies: 3Last Post: 16th May 2007, 03:20
