  1. Hi everybody,
    I have an "mpeg2" (i think, how to be sure according to you???) that i want to convert to vcd, i tried with tmpgenc, dvdx, virtual dub... but nothing work.
    Do someone can help me, thanx a lot!!!!!
    PS : excuse my english, i'm french.
    Bye
    K
    Apr 2002
    The State of Frustration
    What happened when you loaded the file into TMPGEnc, selected the VCD template and selected Start?
    Hello.
  3. In fact, i used dvdx (because tmpgenc said that the format was unsupported) and i haven't sound at the end of the encoding....have you got any idea????
    Thanx
    K
    Apr 2002
    Go back to TMPGEnc, and use this suggestion and let me know what happened.
    If you get an error message when opening the video or audio like file unsupported
    or you get an empty(black) video preview window
    or the video look wierd in the video preview window like green or purple or pink
    Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.
    -- The Newbie Guides
    Hello.
  5. THANX A LOT, it seems good.
    Fortunately, some guys like you helps some guys like me.....thanx.
    Bye
    K
