Hello, I'm currently trying to rip Sakura's Diaries, and basically i am having a LARGE AMOUNT OF PROBLEMS WITH MAESTRO. and SUBRIP. Basically, I re-encoded the vob from 2 gig to 1 gig, a peace, right via TMPGenc. okay... now I used maestro because its the only software that seems simple enough to use for DVD authorizing, i wish spruce up had subtitle support. at any rate, now to the problem. I have a .m2v file that is approx. 43:46:15 Timecode.. and The subtitle is 43:49:13 Timecode, now I basically used subrip and did some time correction, it took me awhile but I eventually got the subtitles to be exactly 43:46:15. just like the .m2v file, now I tried to add to maestro and again I keep gettin this timing error, or something about how there is no corresponding subtitles found. or that the file isnt specified to the same timecode. I WAS WONDERING IF ANYONE ever gotten this Problem.. and if they were about the fix this.... thanks.... any info would be helpful..
i had a similar problem and error message.
what it was i had my .son file in a different folder to my .bmp.
i put them together in the same folder and then it accepted them. -
thingimijig:
THANK YOU SOOOOOOOOOOO MUCH, I HAD SOO MUCH RIDICULOUS PROBLEMS LAST NIGHT MY HAIR WAS FALLING OUT... THis relally did work... THAT IS A HUGE BUG.... ehhehe, too bad they are no aroun for us... hopefully apple will make something better with spruce tech. thanks again
pookeye
Timing issue with different programs.
By Jon.G in forum Authoring (DVD)Replies: 1Last Post: 15th Nov 2010, 02:35 -
Audio/video/subtitle sync problem converting MKV to DVD (Muxman issue?)
By crackerbear in forum Authoring (DVD)Replies: 3Last Post: 7th May 2010, 11:23 -
.SRT to .AVI timing issue
By CLP31 in forum SubtitleReplies: 1Last Post: 19th Jun 2009, 02:04 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05 -
Problems with timing using Subtitle Workshop
By Antus77 in forum SubtitleReplies: 1Last Post: 24th Jun 2007, 20:27
