I have converted a few .avi (DivX) files into mpeg-1 and they have all worked fine. I downloaded a new movie and am now trying to burn it in mpeg-2 (svcd). The problem occurs when I start using the wizard in TMPenc as usual and as soon as I choose my .avi file as my video source it starts some process called "JUDGING FIELD ORDER". This would be fine but it freezes the whole program at 9% every time? If anyone could please help me I would be very greatful. Thanks.
Check to see if you have any bad frames in the source. That may be the reason why TMPGEnc stops at 9% of your encoding process.
Thank you very much for helping me! I just decided to do the movie manually and it seems to have worked. Thank you though.
Field order is irrelevant in any case when encoding from DivX, as DivX does not have any fields.
Field Order Question
By daz1976 in forum DVD RippingReplies: 2Last Post: 11th Feb 2010, 09:27 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
Determining field order
By dadrab in forum Video ConversionReplies: 2Last Post: 4th Oct 2007, 15:09 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14 -
About TMPGEnc judging field order
By jmayme in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2007, 13:56
