Any help would be greatly appreciated as i am a newbie and don't know much, and smell bad. I have a teac cd-w54e and when i get into nero it says, "The win aspi file ?.? cannot be found. therefore you can only select image recorder." i have the ability to burn music, just no success with movies. nero isn't the only program i've had problems with, so any knowledge that could be passed down would be greatly appreciated.
It sounds like your CD drivers are corrupt, try reinstalling them.
Realmedia! The Nectar of the Tards! -
I'm not exactly sure what the drivers are. like i said, i'm a newbie and i smell. if it's the software that came with it, then that might be a problem because i never got any. i've taken the cd drives out and reinstalled them on many times all with the same result. all i want is to be able to watch movies i've downloaded from the internet, on my standalone and so far i've done nothing but dissapoint myself. again, any help is greatly appreciated.
Have you installed norton ghost. This exact same thing happened when I installed norton ghost on my computer. I have ghost 2001 and Nero 5.0 running. I even contacted symantec and they said it was a nero file. Try running the nero setup. If that doesn't work. Uninstall nero completely and reinstall it and it should fix it,it worked for me.
Best of luck to ya.
I have an annoying problem with my dvd burner.
By roomgrey in forum DVD & Blu-ray WritersReplies: 6Last Post: 19th Oct 2010, 13:43 -
burner causing problem with wireless internet
By zerocoool in forum DVD & Blu-ray RecordersReplies: 6Last Post: 6th Jan 2010, 01:19 -
USB External Burner Problem- help?
By Super Warrior in forum ComputerReplies: 1Last Post: 3rd Jun 2009, 22:50 -
Benq EW162I DL burner Problem
By wanghiking in forum Authoring (DVD)Replies: 9Last Post: 20th Nov 2008, 19:09 -
Problem with HP DVD300e burner
By shinyranker in forum Authoring (DVD)Replies: 4Last Post: 22nd Jun 2007, 07:18
