Hi, Trying to create Vcd/Svcd by following the guides on this site but falling down at the first hurdle. I'm sure I've followed the instructions properly, but every time I try to extract the audio using Virtualdub I get the error message 'the requested audio file is not compatible with the input format. Check the sampling rate and channel count....ect '
I've installed the nimo codec pack and tried several different divx files and also xvid files.
What am I doing wrong?????
Please help!!!
Use HeadAC3he to convert the audio to wave. See the Tools section at left. Also, remember to use the Search function before posting. It may save you some time. It is how I found your answer.
Hello.
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 13:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 19:49 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 07:45
