i've been trying to convert a [Quicktime].mov file to a .mpg. i've tried using Adobe Premiere w/ Pan.Mpeg1 Enc, RAD Vid. tools w/ total recorder, and Digigami.
and with no luck, i can't get any results!
i'm trying to convert a small 20mb file so that i can put it on VCD.
i have successfully gotten the .mov to a .avi, but it has no sound.. so i used total recorder to capture it.
i tried using TMPGEnc to put the audio/video files together to produce a .mpg.... but all i get back is the sound.
i need help, i'm gonna go crazy!
I have also been trying to convert mov to mpg. If Rad Video Tools doesnt do the job, try MOV2AVI.
The MOV files I was trying to convert were slightly different, if RAD didn't worked, I tried MOV2AVI and vice versa.
Cinemacraft supports MOV, but it didn't like my files.
TMPGEnc also supports MOV, if you install the plugin, but I found it very very sloooowwww.
Once I had the AVI, I used TMPGEnc to convert to VCD.
You can find MOV2AVI at http://www.mpegx.com or http://www.divx-digest.com. -
where can i get that PLUG-In for TMPGEnc ??? i only have a 17mb file that i wanna convert.. so even if its slow, it won't take too long. ....??
as long as it gets the job done well.
love quicktime .mov files... such a hassle. -
The QT plugin for TMPGenc is at http://www.geocities.com/SiliconValley/4942/svcd.html you can find this link under convert to the left, but it's not listing under tools (aka d/loads) for some reason...
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
SOLID ANSWER: .Tivo to .MPG or MOV
By DarkPhoenix77 in forum MacReplies: 24Last Post: 5th Feb 2011, 16:43 -
Trouble converting .mov to mpg
By jay_lubb in forum Video ConversionReplies: 1Last Post: 9th Mar 2009, 02:14 -
how can i convert .mov to .mpg?
By johnnylonghair1 in forum MacReplies: 4Last Post: 6th Apr 2008, 11:30 -
By chalutz in forum MacReplies: 7Last Post: 11th May 2007, 09:51
