I'm trying out the demo version of CCE but whenever I drop an AVI file on the program, after the encoding setup dialog, I get the error 'Read Only 0 bytes, while expecting 8 bytes.' I've tried various codecs and resolutions for the VirtualDub captured source AVI file, but I get the same message each time. TMPGENC has no problems with the files. Any ideas?
NiteCretr
If you have a AMD processor and are using CCE v2.50 then it might be giving you problems with encoding the audio. I used to get that error then someone suggested to encode the video only and use another program for the audio
then mux it all together. It worked for me. No problems since.
_________________
<font size=-1>[ This Message was edited by: gambit32 on 2001-08-28 21:02:59 ]</font> -
don't think its specific to AMD, read in a few places CCE is crap at audio when using VBR....using a athlon 1.2 gig.....and have no probs at all...tho i have always done the audio separately
using CCE is a hassel but the results are worth it
I'm running a Pentium III 1Ghz. I haven't
tried demultiplexing the file, encoding the
video, then multiplexing the file back together.
Something to try tonight. Thanks.
NiteCretr
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 16:51 -
NEW VERSION: Cinema Craft Encoder SP2 1.00.01.01
By devilcoelhodog in forum Latest Video NewsReplies: 10Last Post: 18th May 2008, 11:46 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
