I've made my first vcd, got it encoded fine with TMPGEnc, burned it with Easy CD 5 Platinum, but am having difficulties.
First, TMPGEnc will not work without Ace Mega Codec installed, Easy CD won't work with it installed. I had to uninstall it to get Easy CD to work & reinstalled it to get TMPGEnc to work again.
I Got my first movie done by splitting the avi in half with TMPGEnc & then burned with Easy CD onto 2 cds.
However, I'm working on my 2nd movie now & got the first half done but when I go to do the 2nd half, everytime I get to the final screen that says bitrate setting, with the ruler that shows how much of a disk it will take up, it keeps adding the part that I indicated that I now wanted encoded to the entire movie & keeps showing bigger & bigger files everytime I try to set it up to go. It's now showing that the file is 254 minutes. If I start the file encoding, it starts on the 2nd half of the movie where I've indicated it, but it's showing like 7 hrs to encode & the huge file set to be encoded. I can't get the old stuff out of the program that's already been encoded. Help, this is very frustrating.
Results 1 to 1 of 1
SOLVED: Media Player Classic and codecs for Easy Subtitles Synchroniser
By bahjan in forum Software PlayingReplies: 0Last Post: 2nd Feb 2012, 12:43 -
Worth upgrading from sony platinum 8 to platinum suite 10?
By helper in forum EditingReplies: 0Last Post: 30th Jul 2010, 00:30 -
Sony Vegas Platinum 9.0 & Architech Studio 4.5
By bpinto0805 in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2009, 19:02 -
DVD Fab Platinum 3.08.6 & Vista
By ochsfamily in forum Software PlayingReplies: 1Last Post: 19th Dec 2007, 12:10 -
Newbie Question about Sony Vegas 8 Platinum & Flash or HDD Camcorders
By rico_ita in forum EditingReplies: 10Last Post: 17th Nov 2007, 14:05
