Nobody could seem to have any suggestions, so I'll try a different forum.....
I've been working on this for a couple months, and still no luck. I'm burning basic svcd's with vcdeasy. 1 main menu, and a second one for scene selection. I use vcdeasy to make both. The main menu comes up fine (with a link where you hit 1 to go to the first clip and play movie, press 2 to go to the scene selection menu, which has the numbered scenes). The first menu comes up fine, but the second menu never comes up consistantly. You hit 2 to go to the second menu, and it still displays the first menu. It actually goes to the second menu, because the buttons work for scene selection, it just won't display. I've tried and read everything I can think of. If it's a size problem or something, or if anyone can give me any suggestions, I'd really appriciate it. Thanks.
Results 1 to 1 of 1
Avi2dvd menu problems
By bman321 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2009, 20:18 -
menu problems
By jerichoy2j316 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 29th May 2009, 12:13 -
Ulead MovieFactory 6 Menu problems
By cheeseandcrackers in forum Authoring (DVD)Replies: 7Last Post: 18th Jan 2009, 01:59 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
Menu Problems - No Roll Overs - Where are I in the menu?
By dunncha in forum SVCD2DVD & VOB2MPGReplies: 81Last Post: 10th Nov 2007, 08:40
