I have some Yugoslavian movies on DVD which i would like to translate into German, make subtitles(switchable if possible) and add them to DVD.
Is there any way to do that? Which programs should i use? Is there any guide on the net, because it seems that i can't find any beside those "how to rip subs...."?
why donīt you read the subtopics from this forum, entitled "ERROR! - " is not a valid integer value" and "how to add subtitles and to create chapters of an mpg". There are mine and I think they contain at least partially the response to your question.
When you read the part with the opening of the *.sub file with an text editor, note that you can translate the subtitiles line after line in your own language.
With Winsubmux or Submux you can introduce up to 4 subtitles in the mpeg file. They are multiplexed in the mpeg stream. I admit, I didnīt try, I will today, but I donīt get the errors anymore.
iPod touch video with switchable subtitles
By txporter in forum SubtitleReplies: 5Last Post: 13th Jan 2011, 15:35 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 12:52 -
Creating a DVD with Menus and switchable subtitles on Mac OS X
By koke_broke in forum MacReplies: 7Last Post: 27th Mar 2009, 12:43 -
How do you add switchable .idx / .sub to dual audio .AVI (XviD)?
By NextJinGamer in forum SubtitleReplies: 4Last Post: 1st Jul 2008, 16:42 -
How do I add switchable subtitles when converting to DVD?
By Baldrick in forum SubtitleReplies: 4Last Post: 15th Aug 2007, 01:32
