I am new to Ulead DVD Workshop, and am having a problem finishing up a trial movie.
I have 3 video clips, all mpeg-2. I also created a menu with a button that says "Play" to play the entire movie, and moved the first of the video clips into the button to link it.
When I do the "trial play" in the "finish" part of the menu, the movie does play all 3 clips, but there is a slight pause in between the clips.
Question: how do I get rid of this pause?
Hi,
If you are using three mpeg2 files, this small pause is normal.
If you want to get rid of it, simply join the 3 files on 1 .
There are lot's of software to do that .
You can even use TMPGEnc's Mpeg tools .
Question about Subtitle Workshop
By tcory in forum SubtitleReplies: 1Last Post: 15th Jul 2011, 23:10 -
DVD Workshop 2 - No Audio in Windows 7
By KTH in forum ComputerReplies: 3Last Post: 27th Dec 2010, 16:08 -
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Subtitle Workshop 2.51 question CLI vs Gui.
By Maikeru-sama in forum SubtitleReplies: 0Last Post: 4th Jul 2008, 21:27 -
DVD Workshop 2 on Vista
By jaffacaique in forum Authoring (DVD)Replies: 6Last Post: 22nd Aug 2007, 09:16
