Hi, I'm new to his so probably this is just a silly question. I've just converted an avi. file to a mpeg. file and put it on cd-R using TMPGEnc and I also converted the audio of the movie to a wav. file and I used Toolame in the TMPGEnc program to convert the audio. But when it has finished encoding and I play the movie in MPEG format the audio really isn't good. What have I done wrong here?
Thanx in advance,
Stefke![]()
Here is something I like to do:
After extracting the audio, open up tmpg encoder and select new project and load the wav file but dont load the avi, leave it blank. On the bottom of the screen it will tell you what audio rate the wav is(128, 192 224 ect.)
I then encode the movie as an XVCD or Svcd, But all I change is the audio rate, If you need to that is, to what ever the wav is, that way tmpg doesnt have to change anything. Ive noticed a big difference between the way I am supposed to do it and the way I do. I find that the audio sounds way better.
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
Help please! Easycap DC60 no audio and bad quality video problems!
By thorn1414 in forum Capturing and VCRReplies: 2Last Post: 17th Oct 2010, 09:24 -
Getting bad quality with AutoGK
By alc112 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Aug 2010, 08:37 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
nero with bad audio quality?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 1Last Post: 3rd Sep 2007, 04:07
