i am trying to use tmpgenc and do audio only but it won't let me select audio only under the stream type. how do i get that to enable so i can get that. i am working under the subject HOW TO PUT VCD MPEG 1 VIDEO ON DVD+RW and it says it won't work with divx so i thought i would convert that to a vcd without burning it to a disc and then use that and do what it says that way well it is working so far i just can't get to enable the audio only under the stream type. so how can i? sorry for rambling
I'm not sure what you are asking...but.
In TMPGE > Audio Source > Click Browse > load Audio >....thats it!
If you want to make some changes to the audio ...
Setting > change frequency,bitrate etc.
Your output will be a MP2."Today is only yesterdays tomorrow"
TMPGEnc Authoring Works 4 Problems
By DJ_OB1 in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2009, 12:20 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
