In Nero what settings do you use for burning data files? I have used UDF/ISO 1.2 with Joliet & long filenames and it seems to work ok. I'd like them readable on Win98 and up.
Panasonic DMR-ES45VS, keep those discs a burnin'
U just said that works for you, why not just keep that?
I personally use ISO DVD, it works fine on my laptop n desktop (XP Pro and XP home)
The right software? (dvd burning/movies/data)
By Sm12 in forum Newbie / General discussionsReplies: 1Last Post: 12th Mar 2010, 19:45 -
What burning software records a data DVD from playlists?
By Stealth3si in forum Newbie / General discussionsReplies: 0Last Post: 12th Jan 2010, 23:43 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
DVD Data Burning Query
By gilera in forum Newbie / General discussionsReplies: 17Last Post: 4th Feb 2009, 04:32 -
Burning data-dvd
By btkuehn in forum Authoring (DVD)Replies: 37Last Post: 9th Oct 2008, 19:55
